Re: Low RPM's
if i left the 15 x 17 prop and went with a ss prop what would this do?
It is typically recommended to drop an inch of pitch when switching to a SS prop.
In your case that shouldn't be necessary, because most of the 17" SS props are of a smaller diameter(example: 14.25 X 17). The 3/4" decrease in diameter will offset the need to drop pitch, resulting in nearly the same WOT rpm, and improved all around performance. The debate involves whether the increase in performance is worth the triple price tag.
The use of the stainless prop with it's additional cupping should allow you to raise the motor higher on the transom(reducing drag) to gain even more speed (and rpm). Usually you can raise the motor at least one hole higher.
So; while usually gaining 1-2 mph, by raising the motor you could see 3-5 mph. Results vary depending on the boat.
Looking at it in terms of efficiency, by putting the SS prop on and gaining 2 mph; that translates to an increase in efficiency and better gas mileage, as well as better acceleration, cruise, top speed; everything.
