I bought this j15rccs motor 2 years ago. I have had an adventure and learned a lot from you faithful people on this forum.
This motor is mostly a 1988 j15rccs. However; I have discovered that some of the parts on this motor are from different years. With your help I have gotten this motor to run, and starts easily, and successfully now, with one or two pulls, most of the time.
My question now is about the slow idle needle. It must not be the correct one. I purchased the knob to go on the needle so I can adjust the idle without opening the cowl. However; the knob does not fit. The end of the needle is too small. I bought a small pipe clamp to tighten the knob onto the needle but even when the knob is clamped shut it does not grab onto the needle.
Any suggestions on how to make this knob fit? or should I but the correct needle?
I have been successful in adjusting this needle to make the motor work if the motor is in a plane position, but if I am in shallow water and need to trim the motor up, then it does not run well.
I'm thinking I need to buy the correct needle. What do you think?
