logger8614
- Mar 18, 2009
- 7
I have a ranger with a 2006 opti/60hrs under warranty. Last two trips smartcraft has generated an alarm. 1 beep and flashing pic of engine. Always with throttle under 1000 rpm in a 5 mile /hour zone. It will cease with slight throttle advance. Took it to dealer and 200 dollars later I have a new battery and the same problem. Computer diagnostic showed low voltage event. Happens after a good 7-10 minutes at lowest of thrust. At running speed smartcraft reads 14.2 volts.
Sitting in driveway smart craft reads 11.9 volts after two hours on water and no charge / first run on new battery. I ran radio and tilt trim a couple of times to dissipate surface charge for reading in driveway.
Is this a phantom alarm, is my alternator on the fritz, possible loose wire?
Oh by the way should I ask for /expect any consideration for paying for initial diagnostic when I take it back to dealer on Monday or has that ship sailed. Feel like two bills to not solve problem should be considered by dealer on Monday. Am I out of line?
Thanks in advance Joe--wish the answer was a can of sea foam
