Themanofsteel
- Jul 11, 2015
- 312
On my Mercury Blackmax 150 outboard, I installed a pressure gauge. At WOT pressure increases to about 20 then drop drastically to about 12-15psi and hold there. My overheat alarm eventually triggers.
The impeller has been changed more than once.
The poppet and all parts are new.
Replaced the cylinder head gaskets and the exhaust manifolds as well.
I extended the drive shaft housing, water tube & drive shaft to make it a 25”. I confirmed the water tube is the correct length FYI.
I cannot figure out why I have such low pressure. Been dealing with this issue for some time.
