Hello...I have read many threads regarding this issue but just wanted some clarification.
I have a 2006 Lowe FS175 with 2006 Merc 115 Four stroke and I am not at all satisfied with the holeshot. I bought the boat based on being told that it will pull up a skier no problem yet it is unable to get me out of the water. (190 lb skier.) So my plan is to start raising the motor in the transom and then consider another prop as advised many times in this forum.
However....Lowe says don't raise it and two separate dealers say don't raise it. What is the deal???? The one dealer has the same boat with the 115 optimax and he says it pulls him up no problem. How can the two stroke of same HP be that much stronger??
Currently have 13.25 X 17 Black Max....achieving 41 mph @ WOT @ 5500 rpm with 4 ppl in boat. Motor in lowest position on transom.
All your advice is greatly appreciated...thank you.
