Lowe Legacy taking on water !
dconant
I have a new Lowe Legacy ,It takes on water.Has anyone else had this problem? Does anyone know where I should be looking to find the leak? I have plugged all the live well intakes and have put plastic tape around the screw in drain plug. If it was just a little bit I wouldn't mind but it's taking on a lot of water. Thanks for any advise.
paulswagelock
Dealer issue, but if you want to troubleshoot, in the driveway place a hose in the bilge and start adding water, look for the leak OUT of the boat.
Now I make this recommendation without knowing or seeing your particular boat so there could be reasons you don’t want to do this. You need to assess.
