Re: lower alpha 1 unit
hello<br /> shift the lower into fwd and place the boat shifter into fwd and rotate the prop counterclockwise to line up the drive splines. if you rotate the prop in the least amount in a clockwise direction you will have to shift into fwd again.<br /> good luck and keep posting
