Lower cable bad?
bmiszuk
74 Larson Trihull Mercruiser 140hp I/O
How much force should it take to move the lower cable? When I disconnect the cable from the linkage and try to move the cable by hand, it takes quite a bit of effort to get it fully engaged so the prop will stop turning.
Could the cable be bad? What's a normal amount of pressure it should take?
Bt Doctur
Re: Lower cable bad?
Thumb and index fingers coated with butter on the plastic slide
