1985 50hp.4cyl. 2carb.
when I got this engine in 09 the compression was 130, 130,125 and 100 on no.4,
I replaced the lower crank seals then, now the compression on no. 4 is down to 85.
Are the seals damaged by the exhaust heat and pressure combined with the water?
If so is there a way to keep the exhaust and water away from the seals? I would
like to overhaul this engine next winter and would like to find a more permanent
fix then replacing the seals every other year like the water pump.
I hope you dont think this is one of those dumb questions.
THANKS TO ALL..........HAS
