Hi, I had to rebuild my lower end due to water and resulting rust freezing up the upper shaft bearing (below the waterpump). After replacing the shaft seal, the driveshaft seal, the oring and the oring on the gearcase I figured I was all set
. However, I have tried putting this thing together several times
with no seal (5 PSI air blows out at the propeller end where the gear case seals to the round disk thingy). I am guessing that you must have to use some sort of sealing compound where the end of the oring goes up against the round disk thingy. Can I use the blue gasket material that NAPA sells, or is something special required? I also have some gasket sealant (the kind that doesn't harden).
I have two big twins in my garage right now that suffer from this same issue and which I have rebuilt both bottom ends, so the learning will be applied to both of them, so double thanks for any advice!
