lower end
tomhunt
just done water pump service to my mariner 140hp international outboard and cant for life in me replace the lower end it only goes so far up, I am a tradesman but by no means an outboard tech or mechanic, please what do I need to twist or turn?
Wingedwheel
Re: lower end
Make sure the water pick-up tube is aligned and possibly turn the flywheel by hand to allow the drive-shaft to slip into place. Also put a little grease on the splines of the drive-shaft. Not so much for installation, but for the next time you want to remove it.
Mi duckdown
Re: lower end
What Winged wheel posted. plus a third hand is always handy to turn the flywheel.
Jack Hart
Re: lower end
The shift shaft may be the problem. Shift to forward, then turn the shift shaft on the lower unit clockwise. See if that helps. You may have to wiggle the shifter.
M
Maxz695
Guest
Re: lower end
make sure the exhaust pipe is inline, and the water tube is moved to insert position also make sure your shift shaft is in nuetral and the shifter is in neural. If you removed the cam on the shifter shaft make sure it is in the right position. the cam locks the engine down in reverse so the engine dosn,t rise in revers. if this is not correct the push pin will destroy the cam and you will have to replace it. also make sure you exhaust pipe gasket is right side up this will not only destroy the gasket it will definitely hinder the lower unit from going back up
