lower gearcase reassembly
tommegna
I replaced the seals and o-rings in the lower gearcases of a 40 HP 1989 Evinrude Outboard and reassembled the lower until and now the gears won't engage the Prop Shaft. Any help is deeply appreciated
Tight Lines
CAPTAIN TOM MEGNA
Joe Reeves
Re: lower gearcase reassembly
Gearcases? Plural or typo?
With the lower unit removed from the engine.... does it shift into both gears and back into neutral as it should?
Did you change the height of the shift rod measurement?
If with the lower unit removed from the engine, it does not shift properly either... something is not assembled properly within the lower unit.
If the lower unit shift rod measurement (a critical measurement) has been changed, you'll need to have the lower unit on the bench to set it properly.
