Lower leg unit
johnnyo34
On my 1973 Mercury 50hp, if I put the lever in neutral, I can spin the prop both ways freely, if I put the lever in forward, I can't turn it to the left & it will ratchet to the right. If I bring it towards reverse there's kind of a first notch,(kind of a stop), it ratchets both ways, if I bring the lever a bit further back, I can't turn the prop to the right, but it will ratchet to the left, not as easy ratcheting as in forward. If I bring the lever completely back, then I can't turn the prop either way..
Is this normal??
thanks
