Lower or Upper Unit
Hodes11
74 Searay 302 5.0L 225 HP Mercruiser. How do you know if the lower or the upper unit has gone out. I know one of the two have or maybe both. Lower unit shouldn't even engage if put in gear right? Started it up, put it in forward engine dies. Start it up, put in reverse nothing engages and rpm's go up. Please help or advice. From Chain Of Lakes Area in Illiniois, if anyone knows mechanics or a side job.
Re: Lower or Upper Unit
Ayuh,... When you find that Mechanic, tell 'em you need a complete transom assembly Rebuild....
The lower shift cable is Junk,+ causing your Problem...
I'm guessin' the rest of the rubber/ replaceable parts in your transom are Probably in the same shape...
Hodes11
Is this a do it yourself project? Are these parts expensive?
Ayuh,... It can be a Real Knuckle Buster,...
Figure $300. to $500. in parts, depending what's found...
