Lower Shift Cable Replacement
FreeBeeTony
I am going to be replacing the lower shift cable on my boat this year.
First time attempting this project. I believe it's an MR1(?) drive (lower has the pin on the drive shaft).
Is it recommended to replace the upper shift lever also?
Fishermark
No reason to replace the lever unless it is worn or corroded up.
I would consider replacing the shift shaft bushings with the newer style if you haven't already.
FreeBeeTony
Thanks for the tip Fishermark, that's the kinda info I'm looking for.
Are they easy to replace? Are they pressed in?
How about a P/N?
Thanks.......
Fishermark
Part number 23-805041A2
And yes - they are easy to replace - tap out the old and press in the new.
Fishermark
Pictured here:
FreeBeeTony
Thanks again...how can I tell if they were replaced w/ the new style
​I've had the boat for 10yrs.
Fishermark
The new style sticks down into the exhaust cavity quite a ways. Look at the picture posted and compare to what you have.
johnkom
I had a stalling issue when shifting that prompted me to change the lower shift cable (MC-1.) Didn't fix the issue. Still stalled, only not as much. I load and unload in a river current. So stalling when shifting is a real ***** of a problem. It's an old boat, 1976, so I figured nothing to loose changing the upper cable. Fixed the problem. Stalling when shifting is not "always" a lower shift cable issue.
By the way, I compared the new cable with the old and there was a noticeable difference in the drag of the inside wire.
JK
FreeBeeTony
No stalling problem.....a little stiff going into gear.
​Been 10+ yrs.....just think it's time.
flipbro
Master Chief Petty Officer
Fishermark what is the orange plastic peice called thats holding your shift cable? FreeBee 10 years its likley time. Hows the bellows look?
Ayuh,.... Time flys,.... seems like it was that long ago, you were puttin' closed coolin' on an I6,...... ;)
FreeBeeTony
Hey Bondo.......yes, time is traveling very quickly.
​This coming season will be my 12th w/ this boat.....hard to believe.
Remember all the problems I had in the beginning? Drove DonS nuts!!
Fishermark
rcmpvet has it right - it is an aid when installing the outdrive. It helps keeps things lined up. Not essential - I went years not using it. But once you have it you will be amazed at how much easier it is to install a drive. ESPECIALLY if you do it by yourself as I usually have to do.
FreeBeeTony
Checked my bushings today....looks like they are the newer style.
​Thanks Fishermark for the tip! One less thing to do.......
