My4winnsLost
- Aug 20, 2005
- 8
I have a 1988 four winns with a gm 3.0 I4 and an OMC Cobra outdrive. The first time I had it out the outdrive was clunking like it was coming in and out of gear. A friend of a friend who hopped on my boat to help out said it was probably the lower cable, either out of adjustment or about to go bad. He tinkered with it for a few minutes and made it easier to shift, but I still had the clunking isssue. This weekend I had it out and when I went to put it back in forward gear I started moving backward. After I pulled it out of the water I cranked the engine and the prop was spinning, so I'm pretty sure teh cable either broke or got jammed in the reverse position. I don't know much about boats, but I'm a pretty good shadetree mechanic when it comes to trucks, so I think I can handle changing the cable if I had a little instruction. Can you guys give me heads up as to what's involved? Thanks!
