lower unit bolts big twins good idea
pcrussell50
specifically for a '59 rds21b 35hp super seahorse
I was going through the lower unit gearcase and munged up the slotted screwdriver headed 1/4-20, stainless bolts. unhappy with the idea of using slotted bolts again, and no telling if they are still available or at what cost. I had an idea. I went and got some stainless bolts from arp, with a 12-point head on them. afaict, 12 point heads when used withva 12 point socket tolerate the most torque before stripping. now the trick came because the shoulders were too wide. .. I had to "turn them down", except I don't have a lathe. so here's what I did: I got a 1/4-20 turnbuckle from big orange racing supply and
just barely threaded it in. then I put it to a bench grinder, letting it turn slowly asvtue grinder whizzed away at it. voil?. perfectly round narrowed shoulders. and arp's legendary quality.
F_R
Re: lower unit bolts big twins good idea
If you are going to be doing much outboard work, get yourself a hand impact screwdriver. One of an outboard tech's most important tools. Then you won't be munging up the screws.
pcrussell50
Well, damn... And I even have one of those. It never occurred to me to use it. Oh well. I'm happy with my current solution as well though. We'll see if I remain so jubilant if/when I ever need to split open the gear case again.
-Peter
wbeaton
I believe one of the reasons OMC used those slotted screws was to limit how much torque the "mechanic" put on them to avoid over-torquing. However, I always appreciate when someone tries to improve an old design. Good for you.
