lower unit compatability
busted-bayliner
is there a lower unit that is interchangable with my 1999 90 hp force motor? brand and hp if its even possible thank guys
jerryjerry05
Re: lower unit compatability
Long shaft?Short shaft?
Serial # Model? Any #'s
Usually the gear ratio is different from the 120 to the 90.
It's possible it can be used just have to work on the right prop.
Answer my questions and I'll try for a bigger/better answer.J
busted-bayliner
where can i find the numbers needed isnt merc mariner the same as force????
all i can find is a tag with year an the it says family id or somthing like that
on the tag it say 75hp -90hp
so assumadly 75hp-90hp parts should be the same
foodfisher
Nope, just didn't want you to assume yourself into a wrong purchase.
