Moody Blue
- May 24, 2004
- 3,136
Well so far so good. The hard part was easy and what I thought would be the easy part has me stumped
The lower unit on my 1971 Merc 800 had alot of metal shavings and chips in it when I drained it last fall.
My goal is two fold.
1) I need to find and repair the cause of the metal chips.
2) I want/need to replace the old carbon steel (corroded badly) driveshaft with a newer S/S type.
This is where I'm at. I have two complete lower units of the same vintage. One has the preload pin with angle teeth on the pinion and drive gears. The other does not have the preload pin and has straight teeth on the pinion and drive gears.
I have removed the carrier nuts and bearing carriers of both units without much trouble.
The damaged unit is the one without the preload pin (straight teeth). Turns out the reverse side of the clutch dog is badly worn as is the mating side of the reverse gear. Without a doubt this is where the metal is coming from.
The other unit looks in pristine condition. All edges of the clutch dog, drive gears and pinion gear look flawless to my untrained eye
My plan is this. Simply replace the driveshaft in the "good" unit (preload pin with angled teeth) and bolt it up to the motor. Any issues with this approach?
Here is my problem. I can't get the old driveshaft out of the housing. I've removed the pinion gear nut, not an easy task. The driveshaft bearing is the non-tapered type.
What is my next step?
