griggsmars
- Jun 10, 2010
- 92
I am having several problems with my 1994 Force 120 hp outboard and could use more advice. I already have a thread up about my motor not having any spark then the steering cable is frozen and now the lower unit does not want to come off. I will keep torching the steering cable and hope it comes loose. I'll concentrate on lower unit for now and I have attached photos. My first thought is, are all the bolts out? There are 4 bolts on the sides of the unit and one just in front of the trim tab, not sure if there are any others. I'm not sure how the shifter rod comes loose on this model either. I am also concerned that maybe the driveshaft is frozen in there ? Then, do you put the shifter in forward or leave it in neutral when trying to remove the unit? Sorry for all the questions, but I keep moving backwards everyday. Thank you, Griggsmars
