I backed up with the motor down and scraped and cracked a piece of my lower unit casing. The fin on the bottom broke about 1/3 of the way up. More important the Prop Shaft bearing housing?? which has two bolts to connect it to the lower unit cracked at both of the bolts, now water will get in.
Anyone know where I can get a used lower unit case? although I think a cracked fin won't matter too much, more importanly anyone know where I can get the prop bearing housing? used, I got a tight budget Its a 94 mariner 90hp 3cyc (0g100809)
Thanks
Thanks
