Steven Bates
- Oct 12, 2012
- 33
Hi again, I have issues with my gearbox (check my previous post- 125hp gearbox dramas...)
I tried to shift the linkage once i thought it was central literally 1/3 turn of the nuts at a time, no good. I had it to the point of reverse just clicking in perfectly, but still when it was at the point of going into forward chattering began, and shift rod just jumps crazy... i adjusted to the point of silly both ways... no good.
I've pulled off the lower unit now, as this only a 15 minute job (thanks Frank A...), and thought i would inspect gears for damage... all drained out, ready to go. took bolts of water pump and cover underneath it, tried to remove, no good!!! seems impossible to remove it, skinny looking piece of cast metal... Thats problem 1.
problem 2 is..:
i thought "ok i'll pull out gears via prop housing..." got anode? off, removed the four bolts, tried to remove plate with seal and bearing? in it,.. no good!!
im struggling...
please can someone tell me how to remove these things, and inspect the drive dogs for damage? i looked at frank A's pics from my earlier post, and i just wanna get in there to see... cheers guys thanks
problem 2 is..:
im struggling...
