The lower unit on my suzuki DF 140 had contact with hard bottom and ended up chipping three teeth on the pinion and gear set. Does anyone know if you would normally go ahead and replace the bearing also because of this metal floating around. The mechanic was not going to.
Thanks
Thanks
