andrewterri
- Jun 25, 2014
- 437
I am starting a new post since the last one is kind of old. I have a 89 searay 3.0 alpha one. I was not able to get the outdrive on to began with but with everyone's help I was able to get the alignment correct which was my problem. When I went to the lake last week I was still hearing a ticking when I steer to port or stern. I was thinking u joints since the gimbal bearing was just replaced ( that is why I had the alignment problem to began with), Pulled the drive to change u joints and checked alignment and its way off again. Only one inch of splines marks showing and it took force to just get that. What is going on? Are the motor mounts bad? I have checked the coupler and it spines true. Teeth still look perfect on shaft because I will not use the boat until it is right. I go back to the dock when there is a problem but it is costing us family lake time and I don't know where the problem lies. I have a factory manual on order since the original was destroyed (thank you dogs!!) Do you guys know what the torque spec is on the rear mounts. I can google but trust you guys more. I can not download the manual here on Iboats.
