Re: lower unit leak 1997 Johnson Ocean Runner 150
Replacement of the fill and vent screw washers is a good idea.Cheap too.I would pressure and or vaccumm test the lower unit before tearing into it for seal replacement.It'll save some maybe unneeded work.However if the lower unit fails a pressure or vacuum test and the internal seals are culprit ,might as well do a waterpump replacement while you're in there.Not too difficult at all for a willing person of basic mechanical skills.<br /><br />Some time ago it was suggested that a guy could just use a common bicycle pump and a tapered or threaded fitting to perform a pressure test with the lower unit submerged in a container of water up to the anti-ventilation plate.If I remember correctly,it should hold around 8-10 psi and you may be able to detect bubbles in the area of a leak while it's submerged.I also remember something about not exceeding around 10 psi with the pump,so you'll need one with a guage.Might be easier for some to just take it to a reputable dealer for the test and opt to perform your own work.Of course it may just be the fill/vent screw seals that are leaking.<br /><br />Leak possibilities are propshaft seals,bearing carrier "o" rings,fill/vent screw seals,shift rod "o"ring/s,shift rod bushing housing gasket,and driveshaft seal.
