Re: Lower unit leak
is there water in the lower unit oil ?? is the oil level in the lower unit low ?? if so here is what i did to find a leak
a year ago my father in law's lower unit was leaking from the same hole...(lower unit was losing oil) it ended up being the seal around the driveshaft...
what we did was take the lower unit off, drain it really well and put drain plug back in and tighten, then we put soapy water around all the seals..(driveshaft, shift rod, prop shaft...prop must be removed) and blow a low psi of air around 3-5 psi in the case thru the oil fill hole and while keeping this psi inside the case (air tight seal ) look around the seals the ones that bubble will need replacing...
we regulated the low air pressure by taking a portable air tank and only putting 5 psi in it and then put a blower tip on the hose and inserted it into the fill hole (i believe we had to wrap the tip of the blower in duck tape to get an air tight seal)
Good luck let us know what you find..also really good idea to have 2 people one doing the air and one looking for bubbles
