Re: Lower Unit Linkage for 1977 Evinrude 85hp 85799S ..need to remove lower unit
I removed the cables and unscrewed the bolt about 1/2 inch, put some putty on the arms to keep apart. Easily done. (see attached)
Now I have replaced the impeller. How do I get the rod back through the hole?
Also there was a plastic tubing about 3-4 inches long. There was only one, should there be two and is it required?
