lower unit lube
captain spike
own a 1969 johnny 115 ob w/elec shift i now i need type "c",i was wondering if there is a alternative??any help would be great thanks!!!!
angus63
Re: lower unit lube
wouldn't use anything else but type "c". different viscosity and shear than st'd stuff.
D
DJ
Guest
Re: lower unit lube
You can also use OMC "Premium Blend", if you can find it.
captain spike
Re: lower unit lube
thanks for the reply!!i just didnt know if walmart or another chain had it but under a different name.its of to the local mariner store!!thanks guys.........
nimmor
Re: lower unit lube
I had a 40 H.P. electromatice that required the type C and couldn't find it anywhere other than right here at IBOATS.
ledgefinder
Ensign
Re: lower unit lube
That'll take OMC/Bombardier "Premium Blend". Alternately, at least a couple companies make aftermarket Type C - I think "Lubriplate" (or something like that) is one. If iboats doesn't have it, try boatfix.com.
