Darrell W.
- May 22, 2009
- 13
I needed a different lower unit (Johnson 88 special) and I found one nearby. I drained the oil from it (looked okay) and pulled a vacuum of 15 inches/mercury for 10 minutes and it held okay. So I bought the unit and installed it. After running it on the lake, I cracked the drain plug to check the oil and out came a "vanilla milshake" thick liquid. I drained the stuff and pulled another vacuum. Again it held 15 inches/mercury for 10 minutes. So I reloaded the oil in the unit and tried it again. Yep - you guessed it - "vanilla milkshake" came out again. Frustrated, I checked the lower unit for any visible signs of leakage and found none (seals looked good and no oily residue visible). It looks great! Here's my question: Is it possible for water to get into the lower unit without any oil coming out?
