Re: Lower unit oil change on Merucy 150 HP, 6 Cylinder
I think my manual says 22 ounces (Merc 150 XR-2), but I changed mine last weekend and it took just a bit over 16 when it started to come out the vent hole...just buy the pump attachment at BoatUS or a Merc dealer, but the 32-oz bottle of Quicksilver lower unit lube, and keep pumping it in from the lower hole 'til it comes out the upper, then give the air a minute to escape, pump a little more oil in slowly, and when it comes out the upper again you're full. Good luck.<br />Regards, Rich
