I just put my boat up until at least Feburary, so figured it was a good time to change the lube in the lower units. 1989 Mercury 200 HP and a 1995 Honda 15 HP. It was about 45 degree w/sun out, but I could not believe how long it took for the oil to drain. Definately had the smell of gear oil and looked to be about 90Weight. I didn't put this in, last time in the shop a couple years ago the guy checked and it has water in it and he pressured tested and changed the seals and put in new oil. The oil looked good no water and no metal shavings,WHEW !!!! that was good.
Replaced it w/ 75-90 wt full synthetic lower unit oil by LuberMatic(?) . Now I can relax and not worry about the cold winter. I would think this is acceptable lube, expensive enough at about $11.00 qt.
