I have a 1978+- Mercury 20 HP outboard motor. I know this is the simplest boat maintainence thing there is, and I've done it many times on other motors, but...I am unable to inject oil into my lower unit. Yes, I HAVE removed the top vent screw, and I'm injecting into the bottom hole. It's like I'm trying to inject oil into a brick wall. I pulled the lower unit yesterday (no small task) which was a waste of (all afternoon) time, and of course I couldn't see a thing, so I put it all back together. <br /><br />I've gone as far as connect a tube of oil to the lower unit and stood on it to pressure it up, but cannot get any oil in there. Then I tried squeezing the tube of oil between two boards with a pair of clamps, still nothing... and we are talking fairly high pressure. I can hear an occasional squirt of air through the vent, but I made no progress in a couple of hours of stomping, squeezing, and cussing.<br /><br />What am I missing? Could the lower unit be completly clogged up? I looked into both holes and could not see anything weird inside...probed around the bottom hole with a screwdriver, but felt nothing in there. The oil that drained from it looked OK, no water or gunk. Of course, now I've managed to drain it completly dry, so I've got an unuseable motor.<br /><br />Anybody got any suggestions? Thanks
