Re: Lower unit oil
As said before, any MARINE gear oil is fine so long as it's the right weight (80W90, etc) and meets the standard requirement (ie. GL-4, GL-5 is what most outboards accept). Just remember not to mix different brands or weights of oils as different brands contain different friction modifier additives that will conflict with eachother if mixed. I personally use the Mercury HP GL-5, for the once or twice a year that I change the oil on my outboard, I figure it's worth it, works great and stands up to use...even when your lower unit seals are toast
. Automotive gear oils do not contain the emulsifiers that marine lubricants do, so in the event that a seal does give out, the oil and water will mix with each other. Automotive gear oils will simply separate themselves from water, which can be quite damaging to transmission components such as clutches, gear selector shafts and especially gears and bearings.
