I'm trying to get running a 1957 7.5hp seahorse AD-11. First time working on an outboard. I've got good spark and compression now, so moving on to the lower unit. What I know:
- It isn't from the AD-11. Is there a way to i.d. it? Or is it unimportant because if the housing fits the AD-11, does that mean that the internal seals etc are probably all compatible too?
- I did a little research on this forum and I have the original cast impeller housing 303442, impeller #434424. The impeller was actually quite flexible, and not worn down. But all comments say to replace, so that's what I'll do.
- I pulled the drain plug and about 10 drops of yellow oily water came out. Never having resealed a lower unit, turned to youtube. Getting the seals out seems like a big challenge for my limited tools. But I'm already this far….any advice? Buy a seal kit and go for it - or leave well enough alone, reassemble, and bucket test?
-Brent
p.s. I'd add photos but the website's not been letting me do that for a couple days...
-Brent
