Lower unit or housing
gustafsonerik
Hi guys 87 mercruiser long story short I got stuck in the mud when I freed myself I notice the engine revving higher then normal and the prop not spinning as fast shortly after I lost all prop movement before i tear it down any suspects where I should look lower unit or in the housing itself just wanted to get you guys opinion first thanks Erik
UNSUREBOATGUY
Re: Lower unit or housing
prop hub slipping? You could check by marking a line on the prop and see if it stays lined up. Just a thought with an easy way to check. Good luck.
joewithaboat
Pray for a spun hub in the prop or engine coupler?
Could have broke a shaft in the drive but it would have gone all at once.
Did you smell any burning rubber? = spun coupler
Give the prop a good looking at...
Drain and inspect drive oil...
good luck!
TilliamWe
Banned
Check the prop first! Don't tear into the drive for no reason.
