Lower unit/outdrive testing....
HOLIDAY120
I have a silly question to ask.
Is it ok to test a lower unit/outdrive with muffs and at the same time submerge it in a water tank? I believe this will allow me to rev my engine and at the same time create enough resistance on the prop to keep the motor from over reving.
I need to use the muffs to guarantee circulation through out the lower unit and motor.
Regards
HOLIDAY120
Bt Doctur
Re: Lower unit/outdrive testing....
Why? even with muffs you could have low water pressure to damage the impeller at hi rpm`s.
jerryjerry05
Never( REV IT UP) on the hose or in a bucket.There just ain't enough water in the hose or bucket.You might be able to do it for a short time but it can collapse the hose and run the pump dry.J
sqbtr
I would think that it would instantaniously empty any container you could put under it.
HOLIDAY120
Thank you all for sharing. Cavitating the pump was always a concern. Just as an fyi, I was only planning on 1500-2000 rpms. I just wasn't sure if even that was going to be too much.
Thanks again
HOLIDAY120
