Re: lower unit ? please respond
thanks jason,I may or may not have someone to do it.Hopefully,the new washer will do it.The old ones did'nt look too good when removed.If it is still leaking after,I'll try to limp it through the rest of the season with very regular gear oil changes.Oh also,It appears that gear oil may have been seeping out between the leg and gear unit,at the joint,where the two bolt together.from the rear where the fin is.Or,it was just running out that direction from the plug not sealing
