lower unit plug stripped
texas_whaler
Anyone ever had this happen before? The top plug has stripped..I can't back it out and I can't screw it in further..The thing is is that when I was tightening it up, the plug never got hand tight..Someone said something about a heater coil or something?? Any suggestions would be greatly appreciated!!<br /><br />Matt
SeaKing15hp
Re: lower unit plug stripped
Someone will come along and help you shortly. I think when you said heater coil, you meant Heli Coil. These are threaded inserts. <br /><br />-Jacob
texas_whaler
That sounds better..I knew heater coils were auto related, but never heard of it in boat motor chat!! Thanks<br /><br />Matt
Chris1956
Texas, Mercury has specific devices designed to fix this problem. I assume Johnson will have a similar device, or one is available for universal application. They are plugs which screw into the original hole (or oversize), which contain a plug. I recommend you check with the dealer.
