Lower unit plugs
volnavy001
I just changed the lower unit oil on my 1990 Johnson 15hp outboard and noticed that there was not gaskets or o rings on the screws. Is this ok? There was not any water in the lower unit.
No there should be a seal on the screws.-----Some screws have an o-ring in a groove.-----Double check and see if the nylon washer stayed in the housing.----Caution.----Make sure you have the screws sealed as the price of new gears / bearings will shock you.
volnavy001
I double checked and the gaskets/ o-rings were definitely not there. I bought original omc replacement gaskets (the same ones listed in the manual) but when I installed them the screws would not seat flush with the lower unit housing which worried me. What am I missing?
kbait
I think the drain plugs that year should have o-ring seals in the plugs themselves. If not, use what you have now. Won’t be exactly flush, but will seal your gearcase normally.
thatone123
Banned
I've come across this also in the same outboard and there did not seem to be any seal unless I missed it.
boobie
The drain plugs that require O-rings have gruves in them for the o-ring. Don't use the 311598 flat washer on them.
volnavy001
OK. I talked to a local guy who said they probably seal themselves. Thanks for all the help.
???----" Seal themselves "----That sounds good.-------Hopefully you have checked the price of gears and bearings should water get in there.------There have to be seals on those plugs !!!
