lower unit pressure test tools
bcasurvey
Is there a link on how to make a pressure/vacuum tester and how to use it?
gm280
Re: lower unit pressure test tools
Most auto parts stores sell a vacuum/pressure setup to self-bleed brakes. Mine has a vacuum gauge on it for bleeding brake lines. But you will need a pressure gauge to use and know what pressure you are applying. I used one of those with an auxilary pressure gauge and a "T" fitting to make a pressure tester to test a lower foot for leaks. Works great too...now all I have to do is fix the L/U prop-seal leak... Try it out, I think you will like it... :cool:
boobie
When you do a pressure/vacuum check make sure you run all moving parts through their cycles. D/S, P/S and Shift rod.
