lower unit question on mercury 850
04whitetb
:)i just got a 1977 mercury 850 on a glastron,i'm freshening up things and was wondering how to change the lower unit lube and what kind is best to use? any help is appreciated. thanks
narvlebenoit
Re: lower unit question on mercury 850
theirs two flat head screws on the lu take them both out drain old to put new oil put oil tip in bottom hole and squezze till it comes out top hole put finger on top hole put bottom screw in then top.You should change them washers on the screws though.And all I use is outboard motor lu oil from wal mart or your local outboard store.
Chris1956
To be clear, use a marine gear oil. Usually they are SAE-85 The gearcase takes 25oz, so buy a quart.
04whitetb
thanks for your responce.i'll pick some up soon.
krs60
What year and model glastron? I recently got a 1977 mercury 850 on a glaston too, 1977 v-162.
