lower unit seal
dustinatdana
If the seals have gone, how big a deal is this (cost and hassle wise) As I'll be pulling the lower for the water pump could I do these myself?
mbb
Re: lower unit seal
depends on which seals. Propshaft seals and bearing carrier O-ring is easy and is done with lu on the motor. with merc, you need a spanner wrench for the cover nut though (pipe with tabs welded to it works good). seal on water pump housing is also not hard once you have LU off. <br /><br />Get a manual, and yes its no problem to do yourself.
