Re: lower unit swap
Start by measuring the shaft length, count the number of splines on the top of the shaft, see if it has the preload pin on the top of the shaft or not, see if the number of splines are the same for the shift shaft, see if it has or if you need a speedo port. I found with my swap on my 50 that it didn't have to be the exact casting number to fit.
