For mercruiser stern drives about 1988..I just put the lower back onto the upper unit (upper already attached to the boat) had a little trouble lining up the bar that comes from the upper to the lower to adjust drive/neutral/reverse---what is the easiest way to check that they are lined up correctly---had boat in drive and lower unit turned to drive setting when I put them together---Is that right? And is there a way to check if it is done properly without filling with grease and taking to water to find out there is a problem?
