juels98
- May 17, 2010
- 37
Hi,
Please bear with me-- I'm looking for some basic steps to troubleshoot my issue. I think it should be pretty easy to diagnose.
I have a 1993 3.0L LX Mercruiser 4 cylinder I/O with I think an Alpha One outdrive.
After having my boat sit winterized for 3 years, I was ready to get it back in use. Lots of forums suggested that the impeller would need to be replaced since it sat this long. So, I watched a bunch of videos and read some sites, and replaced the impeller. I then went to start the boat and it wouldn't. After some troubleshooting and forum help, I narrowed it down to a fuel pump. After a couple months, I replaced the fuel pump and did a tune up and the engine ran. By that time it was late September and I winterized the boat again. However, once the engine ran, I tried testing my work and the new impeller worked great-- running on muffs, the water shot out just like it's supposed to out of the holes. Engine ran great. However, when I put the engine in forward or reverse, the prop doesn't spin-- it kinda freewheels.
Some things to keep in mind:
1. From what I recall, I put it in forward gear before dropping the lower unit and kept it there until all was re-assembled.
2. The shifter has no issues going in to the forward and reverse gear
3. I don't remember why, but I had my buddy push on the prop while the engine was off and I put it in gear, If I recall, the prop wouldn't move, but with a little force it finally did-- my logic may have been trying to move the motor via the prop to see if all works-- don't remember-- sorry. The point being, maybe we spun the prop hub?
4. Could there be a cable or something that I didn't fully hook up? Any photos would be helpful. I've attached a photo I found of when the lower unit was pulled off-- for reference. From what I recall, it went back together pretty smoothly.
So, seeing that engine runs, lower unit kicks water out, able to shift in to forward and reverse but the prop doesn't spin-- what are some things for me to look at? I'm about 90% sure it's a re-assembly issue or the fact that we put force on the prop while it was in gear engine off.
Thank you for your help in advance!
Julian
Julian
