npd4432
- Apr 18, 2006
- 468
This is driving me crazy!! I have replaced the gaskets on the drain and air plugs, changed the driveshaft seal and pressure tested and suction tested. Both tests check out good. I am still getting water intrusion. The only gasket I could think of is the shift shaft o-ring. Could this cause the intrusion?? If so how do you change that thing?? I have the new o-ring but cant for the life of me figure out how to remove and replace the old one. 1983 Evinrude 75 HP E75TRLCTE.
