michaelj1978
 - Jul 8, 2004
 - 50
4-6mph in 12 feet of water at the lake and the prop (stainless) hit a stump.  Everything froze up.  The flywheel would crank about 2 inches then stop and the prop wouldn't turn.  I finally reached down there and moved it with my foot.  Then cranked it again and it started, but you could hear gears grinding and I shut it back off.  Raised the motor up and there was a golfball size chunk of the lower end missing about 6 inches back from the prop.  All the oil and bits of metal oozed out.<br /><br />It's a 1995 50hp Evinrude.  Can anyone help me find the part number or where to get a new lower unit.<br /><br />This happened on Saturday.  I thought my weekend was bad enough when I was casting a worm with my GLoomis $200 rod and it snapped in half between the cork and the bottom eye hole.
