Lower unit
MUDoug
I have a 1991 Regal Valanti 170 with a 4.3 mercruiser outdrive. I was on the water the other day and backed off the throttle rather quick and it loaded up and died. I got it started after letting it sit a few minutes and when I cleaned it out (fast idle in nuetral position) I thought it was growling a bit. When I got home I put the muffs on and started it. When I raised the RPM's I could clearly here the clatter I thought I knew what it was doing and sure enough the prop was trying to turn. Is there any adjustment on the linkage on the outside (with out tearing lower unit apart)? This noise was not there when I winterized last fall. I realize that it is not disengaging all the way out in nuetral. Thanks,
MUDoug
