lower units
88xr4merc
I have an 88 xr4 blackmax 150 the lower unit gear ratio is 1.78 can I put a 1.87 gear ratio on it or will it mess up my motor
Faztbullet
Re: lower units
Wont mess up motor but it will be a little slower on hole shot and you may have to change pitch of prop. The prop you have now will fit but the exhaust will blow around the hub like a chopper prop so watch for excessive cavitation on planing.
Mi duckdown
Re: lower units
I would get the boat/ motor running first. Run and check RPM and speed(GPS). then the the prop can be figured out.
