Lower until help
Jason-Foote
Hello everyone, first post here! I have a 1996 Four Winns with the Ford 5.0 and the Volvo Penta SX outdrive (part number 3968156, 1.66) over the winter my lower unit didn't survive and needs to be replaced. I can't find a lower anywhere with the same part number but some that look the same and are a volvo penta sx... I just don't know what the differences are and if any would be compatible. Any help would be greatly appreciated. Thank you
Horigan
You need a Volvo Penta SX-M drive in that ratio. Try Boatwrench.com for rebuilt units.
How did it fail over the winter?
check ebay. the lower is the same for the SX-M's regardless of motor in front. the 1.66 is common
Jason-Foote
Thanks everyone! That will get me headed in the right direction. I didn't drain the foot oil and I must have had a bad seal that allowed water to get in during the summer months of using it, once it froze it cracked the case. Only thing I could come up with ..
Jason-Foote
Been looking at the SX-m and my part number doesn't match with any of them. Also is the ratio of 1.66 in the upper unit? And so any SX-m will work?
